[SOLVED] what is the most lowest monitor for 1050ti using dvid output
Nov 11, 2018
can i use my 60hz monitor on a HDMI output or is it only limited to the dvi-d male output. im just looking for budget friendly monitors here in the Philippines.
thanks
What are the make/models of your GTX1050ti and monitor?
Most any GTX1050ti will have outputs for dvi, hdmi and displayport.
Which output you use will depend on what your new monitor will support.
I would pick, in order, displayport, hdmi, dvi as preferred connections for a monitor.
