Trojan_Pinata :
USAFRet :
Trojan_Pinata :
Hi all, I was just wondering how my motherboard and os will be effected by the OEM software on my motherboard. Specs:
MSI - Z270-A PRO ATX LGA1151 Motherboard
Intel - Core i7-7700K 4.2GHz Quad-Core Processor
Microsoft - Windows 10 Pro OEM 64-bit
I don't entirely understand the concept of the OEM OS pre-installed on the motherboard. I get its a bunch of programs but what are they?
Thanks in advance
Is this a system you purchased, with the OS already installed?
If so, from where?
No, this is the build I am currently working on. I just want to understand the concept of what programs already come oem.
For Win 10, you really don't need to worry about the difference between OEM and Retail licenses.
The software is exactly the same (as has been since XP), it just the "license" that is different.
And with Win 10, that difference is even more blurred.
Pre Win 10, an OEM license was tied to the first motherboard it was installed with. If you wanted to change motherboards, you'd better have a good reason, and convince MS to allow that.
After the WIn 10 Anniversary release, you can now link your OS license to a MS account, and reuse that on new hardware.
Of course, only one system at a time.
Linking happens here:
https://support.microsoft.com/en-us/help/20530/windows-10-reactivating-after-hardware-change
http://www.tomshardware.com/forum/id-3164428/windows-build-1607-activation.html
And no "programs" come with it.
It is just the Windows OS.
