What is the possible cause of system restart despite of the UPS connected?
fasih321
There is a UPS connected with my System when AC Power losses, the system gets restarted every time. Can anybody suggest me the possible causes?
Processor: Core i5 2500k
Mobo : Asus P8H67 - V
HardDrive : Seagate ST 31000524AS
Power Supply : 450 Watt
amigafan
212
Alternatively switching time of your UPS may be too long.
In any case it seems that when loss of AC power occurs your computer restarts because of sufficiently bad power fluctuation (or very brief power loss a.k.a. "power blip").
Possible remedies:
* try with higher quality PSU
* try with higher quality UPS (or have it checked)
Jantech
101
It would be my guess that the UPS is bad, possibly a bad battery.
I would check there first. You can do a quick and dirty test of the UPS by plugging in a fan into one of the backed up plugs. Start the fan then unplug the UPS, if the fan stops you know there is an issue with the UPS. If the fan stays running the UPS could still be bad but that would be a more advanced issue and would require some advanced test equipment to rule it out.
I hope this helps
