Thanks to all of you, I've read it here
http://www.legitreviews.com/corsair-vengeance-8gb-ddr3-low-voltage-1600mhz-review_1777/8
I'll copy paste here:
The results of our test were very curious. According to our results, there are more factors that lead to overall system power consumption than simply DRAM voltage as set in the BIOS. The Crucial Ballistix kit, which runs at the highest operating voltage, actually demonstrated the lowest power usage at idle, 185W. The Vengeance LP kit resulted in a system draw of 187W, which was better than the Vengeance 1.5v kit, which pulled 192W, the highest in our testing.
As the system load increased, however, the lower voltage of the other kits began to manifest a power savings. Under Folding@Home, the Vengeance LP kit drew 1 watt less than the 1.65v Ballistix kit and 6 watts less than the 1.5v Vengeance kit.
Under memtest, our results were as we expected. The 1.65v Ballistix drew the most power, followed by the Vengeance 1.5v kit, with the Vengeance LP drawing only 286W. This translates into a savings of 12W and 9W, respectively. In an area with a relatively high cost of electricity, this could translate into a savings of about $1 per month, but only if the system was under heavy use 24/7.
Read more at http://www.legitreviews.com/corsair-vengeance-8gb-ddr3-low-voltage-1600mhz-review_1777/8#rIebckEwZMjJ5hTd.99
