What is the recommended wattage (power supply) for the Zotac 1050 Mini (Not Ti)
The is gross overkill and not a serious answer. Any quality 400-500w PSU is more than capable of powering nearly any rig with this particular GPU.
Even 200W PSU would probably be enough. What CPU are you using? Gtx 1050 needs only 75 W max. If you're using something like g4560 which will max around 24W (54 on paper), 150W PSU will be enough. I'd go with 300W to 400W PSU though, so that PSU would work quiet even when rig is under heavy load.
The cpu is going to be an i5-3470 from a HP Pro 6300 (I'm going to buy a refurbished one and stick a 1050 in it)
Is there any good PSU's to recommend that are around that wattage? Because all the ones I'm looking at don't look like you're average EVGA model psu. Or is it probably just more worth it to buy a 400W 80 Plus power supply?
Ok, thanks!
