What is the total power consumption of my pc
mastergamer2014
47
I have a prebuilt pc and just wanted to know. specs below
HP Compaq 500B MT stock motherboard,case fan,and cpu fan
Intel pentium E6500
WD 120 GB HDD
2 Sticks of samsung 2gb ddr3 ram
AMD Radeon r5 240
All running with a EVGA 500w PSU. Also how mush power is allocated to the pcie x16 slot
Thank you.
mastergamer2014
47
is there way i can check
Get a Kill-A-Watt and plug it in and see for yourself.
mastergamer2014
47
trying to get a card a llittle bit better than the r5 240
4745454b
The problem is you have a 10yr+ old CPU. Anything better is going to be held back by your older system, including your 4GB of ram. You can put the newer GPU in all you want, it's going to hit a wall with that slow dual core and 4GB of ram. I would honestly just keep using what you have until you can upgrade everything.
