what is ultra,high,medium,low settings
dgsarve
70
dear frns,
im new to pc gaming , in every forums they are discusing abt the game setting kindly any explain what is that my monitor is 1366*768 resolution.for this wat is the ultra,high,medium,low settings
Those settings are the graphics settings for the game. The vary a little bit depending on the game...but generally think of it has how good the game will look. So low is like a xbox 360/ps3, medium is like a xbox one/ps4, high is a bit better, and ultra is awesome. Of course resolution affects how good the game looks also.
The resolution isn't game settings. Graphics settings is the settings you're talking about. Depending on the GPU and the FPS you're fine with, you can go with excellent graphics with ultra, great graphics on high, good graphics on medium and average graphics on low. All will play on 1366*768 resolution but the intensity of detail will vary.
You'll get 2-5 FPS more on 720p at max.
dudes plz explain the high settings means resol:1366x768
shader : high,texture : high ,is it correct ......can i play BF4 in highsetting without any lag also my pc config is:
MotherBoard : Gigabyte GA-G41 combo rev2.0
Cpu :core 2 Duo E7500 2.93ghz
Ram : 4gb DDR3 1066mhz
PSU : 450w Mercury SMPS
HDD: 1 TB
UPS : Numeric Digital E600 (20 min backup)
LCD Monitor : 18.5inch resolution : 1366*768
OS : Windows 7 32bit ultimate
No you can't, neither your CPU nor your GPU is capable enough, you can always try by changing the settings, but getting 5-10 FPS isn't good or is it? Less resolution puts more strain on GPU as it eats less VRAM thereby leaving some free for actual graphic computing which your GPU is too weak at, to do for high settings. Your CPU on other hand will just not allow enjoyable play on any multiplayer.
