I booted up my computer and I was met with:
Intel UND1, PXE-2.1 (build 003)
Copyright (C) 1997-2000 Intel Corporation
This Product is covered by one or more of the following patents:
US5,307,459, US5,434,872, US5,732,094, US6,570,884, US6,115,776 and
US6,327,625
Realtek PCIe GBE Family Controller Series v2.52 (11/28/12)
CLIENT MAC ADDR: 74 DO 2B 96 1F 17 GUID: ########-####-####-####-######
DHCP../ (<- kept spinning)
After about 30 seconds it came up with another line I can't remember and booted into BIOS. This happened to me about a month ago and I had to switch the boot order, then it worked fine, this time, I unplugged the SATA cable to my hard drive, restarted and it booted to Windows 7 (I have an SSD). After this happened I plugged it back in just to check and I expected it to go to the same screen as before but it booted just fine. I can go into the drive with windows explorer and all my files are there. I'm just a little worried as to what might be wrong if at all. I have this program called CystalDiskInfo and it says my HDD is "Good" but it does not have "100%" underneath like it says with my SSD. By the way the hard drive in question is a Toshiba DT01ACA200 (2TB) - I got it in late 2013.
Any answers are appreciated, I just need to know what is going on
US6,327,625
