Hi, I got my GPU - a Sapphire Tri X OC R9 290 about a month ago fairly used at a great deal. It when I got it, I ran Furmark stress test and noted it's performance. It was okay and it reached a peak temp of 76c. I played games on it for a couple of weeks, with no issues. Two weeks ago, I decided to overclock the card. I followed this guide https://www.anandtech.com/show/7601/sapphire-radeon-r9-290-review-our-first-custom-cooled-290/5y and aimed for those settings using MSI Afterburner. My first attempt was successful, but other subsequent attempts weren't and it was very unstable. So I aimed lower and finally settled for an overclock settings of 1060MHz (base clock was 1000MHz) and a memory speed of 1400MHz (base speed was 1300). I uninstalled Afterburner and used AMD Wattman to perform the overclock. I didn't touch the voltage settings since Wattman doesn't have that option. But I adjusted the Powertune to +10.
About a week ago, I couldn't play any games on it, due to the frequent crashes. And I was unable to properly shutdown my computer or set it to sleep. Each time I tried I would get the (this memory could not be referenced at Radeon.exe) I shutdown the computer using the power button.
I decided to reinstall Windows, thinking these problems were due to a driver update or Windows Update. With a newly installed Windows and a previous driver, I started seeing artifacts on the screen. And games would crash almost immediately - this was in stock settings. I hadn't applied any overclock to it yet. The artifacts appeared every time Windows was booted up.
Expecting the card to be dead, as a last resort, I decided to open up the card and inspect the thermals. The thermal paste applied to it was still moist, and there was no signs of viable damage. I applied a little thermal paste to the card and installed it. It didn't crash this time, with no artifacts appearing and I was able to game for a while. But it ran a lot hotter than before. Rising from a peak of 81c before to a steady range between 88 to 95c. I got some thermal paste and applied to it, some days after and yet the problems persisted. I've inspected the thermal pads and it all seems to be in order, although a bit old.
I've updated the BIOS of the card. And it still runs hot. Running Furmark now pushes the card to a peak of 96c, while earlier, the max Furmark could push it to the was 81c.
I've noticed that a pin in the GPU die is missing.
I'm open to any and all suggestions. I'll update the thread with more details and pictures.
The P.C specs are;
Intel core i7 4770s
16gb RAM
600 watts 80+ Bronze PSU
Barracuda 3TB hard drive
Barracuda 1.5TB hard drive
ASUS B85M motherboard
This is a link to the motherboard problem I'm having currently with the GPU.
forums.tomshardware.com
The P.C specs are;
Intel core i7 4770s
16gb RAM
[SOLVED] - Desktop not performing POST, or booting to BIOS, displays black screen with white underscorei
Hi everyone, my desktop doesn't boot to BIOS, or starts POST. I was having an issue with my Graphics card - it's a Sapphire Tri X OC R9 290. So in order to test the problem, I'd take the GPU in and out of the system and turn it on, in order to test if it was working. This morning after...
