NowJoJo Reputable Apr 7, 2017 104 0 4,710 Jun 21, 2018 #1 Half my screen is pink! Wondering if its some bad capacitors or something? It is always there even with just power so it's not a cable issue... Note, I blurred out my name in the photo
T tcook218 Prominent Oct 31, 2017 59 0 630 Jun 21, 2018 #2 Try unplugging it for like 3 minutes and unplug your HDMI cable and plug it back in. Upvote 0 Downvote
NowJoJo Reputable Apr 7, 2017 104 0 4,710 Jun 21, 2018 #3 tcook218 : Try unplugging it for like 3 minutes and unplug your HDMI cable and plug it back in. Okay, I'll try that and report back! Upvote 0 Downvote
T tcook218 Prominent Oct 31, 2017 59 0 630 Jun 21, 2018 #5 Ok you probably have burnt pixels so the monitor is basically screwed sorry 🙁 Upvote 0 Downvote
NowJoJo Reputable Apr 7, 2017 104 0 4,710 Jun 21, 2018 #6 tcook218 : Ok you probably have burnt pixels so the monitor is basically screwed sorry 🙁 It was perfectly fine earlier today, I was playing shut it off, came back like 1 hour later and that happened... Upvote 0 Downvote
NowJoJo Reputable Apr 7, 2017 104 0 4,710 Jun 22, 2018 #7 Bump before I pull it apart to check capacitors Upvote 0 Downvote
NowJoJo Reputable Apr 7, 2017 104 0 4,710 Jun 22, 2018 #8 No bad capacitors were found... Upvote 0 Downvote
helpstar Titan Dec 25, 2012 14,388 984 83,840 Jul 6, 2018 #9 Can you reset the settings of the monitor?(via OSD) Which monitor is it? Upvote 0 Downvote
NowJoJo Reputable Apr 7, 2017 104 0 4,710 Jul 17, 2018 #10 helpstar : Can you reset the settings of the monitor?(via OSD) Which monitor is it? I have tried resetting it, same problem It's a Asus vs238h-h Upvote 0 Downvote
helpstar Titan Dec 25, 2012 14,388 984 83,840 Jul 18, 2018 #11 should be the led backlight https://www.youtube.com/watch?v=rBhqpwC5ekg Upvote 0 Downvote
NowJoJo Reputable Apr 7, 2017 104 0 4,710 Jul 18, 2018 #12 helpstar : should be the led backlight https://www.youtube.com/watch?v=rBhqpwC5ekg How do I go about repairing that for my specific monitor? Upvote 0 Downvote
helpstar Titan Dec 25, 2012 14,388 984 83,840 Jul 18, 2018 #13 No warranty anymore? Couldn´t find a disassembly video of your model and I´m not sure if you can replace the backlight like in the previous video. Upvote 0 Downvote
