What kind of cable is used for hooking up a graphics card to a motherboard?
thatfancypenn
344
I'm asking this because I really want to buy some BitFenix Alchemy cables for my 780, but I'm not sure what the cable is actually called. Could you tell me? :)
You don't connect a graphics card to a motherboard with a cable, you use a PCI slot. If you want your power cables connected to your GPU a different colour, you can buy sleeving or pay someone to sleeve your cables for you. Hope this helps!
Reactions: ACTIVIUS
I mean the cable that comes out of your graphics card.
Here is one you could buy.
http://www.frozencpu.com/products/14079/cab-593/Bitfenix_Alchemy_Multisleeve_8-Pin_PCI-E_Extension_Cable_-_45cm_-_Red_BFA-MSC-8PEG45RK-RP.html?tl=g2c537&id=6VcJEJgk
Why would you want a different cable though? The one you plug in for your power supply is fine.
Here are more:
http://www.frozencpu.com/cat/l2/g2/c537/list/p1/Cables-Bitfenix_Alchemy_Multisleeved.html
What are all the cables I could get and I would be able to see? Just the 8-pin, 24-pin, and 6-pin?
Not 100% sure. If you want all your cables a different colour though here is a video on sleeving your power supply cables.
https://www.youtube.com/watch?v=92pRjXZ1EMk
No I don't need to sleeve it on my own, I am going to be buying them. I don't have the patience to do it on my own. I just need to know what the cables are.
It's the PCI-E ones (6 or 8 pins). Here's a link.
http://www.frozencpu.com/cat/l3/g2/c537/s1537/list/p1/Cables-Bitfenix_Alchemy_Multisleeved-Alchemy_6-Pin_PCI-E_Ext-Page1.html
And PCI-E is for my graphics card, correct?
Yes. Other devices can be plugged into PCI-E slots, like nice sound/wireless cards but most of the time you will see graphics cards in there.
