JoltGod Reputable Aug 19, 2014 74 0 4,630 Nov 4, 2014 #1 http://ca.pcpartpicker.com/p/Q6cqWZ What kind of Frames per sec should I be expecting with my build?
Solution rolli59 Nov 4, 2014 It will handle that very well but some games you can not run on highest settings.
rolli59 Titan Oct 27, 2007 47,805 285 130,890 Nov 4, 2014 #2 Not much on the onboard VGA! Upvote 0 Downvote
L lightcloud Expert Ambassador Jul 20, 2014 5,204 0 32,960 Nov 4, 2014 #3 With can only give an estimate. 😉 As for your build you will be running Intel HD 4600, which isn't bad or good. As you also did not specify the game, I can say that you will run CS GO at 60FPS and at 1920x1080. If you play it. Upvote 0 Downvote
Thaisnang Honorable Sep 23, 2013 2,350 0 12,960 Nov 4, 2014 #4 There is no GPU in your build. The Intergrated GPU on i5 should 10-20 fps on low-med and 800X600 resolution, in most of the latest games. Upvote 0 Downvote
L lightcloud Expert Ambassador Jul 20, 2014 5,204 0 32,960 Nov 4, 2014 #5 Thaisnang : There is no GPU in your so build. The Intergrated GPU on i5 should 10-20 fps on low and 800X600 resolution, in most of the latest games. How do you know he will get 10-20FPS when he has not specify the game? Edit: I just missed out your edit saying the latest games when I replied, sorry about that. Upvote 0 Downvote
JoltGod Reputable Aug 19, 2014 74 0 4,630 Nov 4, 2014 #6 I put the wrong build up -_- my bad, that was one I was in the progress of making for my cousin. Upvote 0 Downvote
rolli59 Titan Oct 27, 2007 47,805 285 130,890 Nov 4, 2014 #7 Now we are talking, nothing that it can not handle on a single 1080P monitor! Upvote 0 Downvote
L lightcloud Expert Ambassador Jul 20, 2014 5,204 0 32,960 Nov 4, 2014 #8 Wait a minute. The integrated on graphics card on that PC can run games at 1080p. Like Tf2, Monecraft, or CS:GO or oany other less intense game. Please correct me if I am wrong. Upvote 0 Downvote
JoltGod Reputable Aug 19, 2014 74 0 4,630 Nov 4, 2014 #9 rolli59 : Now we are talking, nothing that it can not handle on a single 1080P monitor! How about 1440p? Upvote 0 Downvote
rolli59 Titan Oct 27, 2007 47,805 285 130,890 Nov 4, 2014 Solution #10 It will handle that very well but some games you can not run on highest settings. Upvote 0 Downvote Solution
JoltGod Reputable Aug 19, 2014 74 0 4,630 Nov 4, 2014 #11 rolli59 : It will handle that very well but some games you can not run on highest settings. Thanks, just wanted to know so when I order a new monitor, which I should buy, leaning towards a 144hz 1080p now 😀 Thanks! Upvote 0 Downvote
Thaisnang Honorable Sep 23, 2013 2,350 0 12,960 Nov 5, 2014 #12 JoltGod : rolli59 : It will handle that very well but some games you can not run on highest settings. Thanks, just wanted to know so when I order a new monitor, which I should buy, leaning towards a 144hz 1080p now 😀 Thanks! Get h105 instead of h100i, it has some new features. Upvote 0 Downvote
