What kind of PC Build for gaming and drawing?
Radorun
Commendable
Jun 9, 2016
Hello,
I've been thinking of building a pc, but since I'm a beginner and not really sure about the parts I should choose, I wanted to ask you. The pc will be mainly used for gaming (MMORPG, latest games etc.) and drawing (Photoshop: making it possible to smoothly work on a 3000-4000pixel piece).
Mind that I don't need to go crazy on the parts, like getting the latest CPU, since I'm not performing very intesnive tasks on the pc. Maybe an i5 would be good and I'd prefer a nvidia graphic card over amd. But you guys know better. I'd wish games like Black Dessert, Witcher 3 and Overwatch to run smoothly. It's not a neccessity for the graphics to be on max while playing them.
My budget is around 400-600euros (450-680dollars) and I'd like to know what is the best build I can get for my usage with that amount of money.
Since the Radeon RX480 4GB/8GB will not be released until the 29th of June, would Asus Radeon R9 380 2GB/4GB, for example, be a good replacement? Or would you recommend something else unless you think waiting for the Radeon RX480 is worth it.
I'm over budget too, but I assume that you need a OS. The RX 480 will be a little bit better than the R9 390, so unless you can pick up an R9 380 for about €90, I would wait for the 480. You can use your i3 video IGP until it's available.
CPU: Intel Core i3-6100 3.7GHz Dual-Core Processor (€120.04 @ Mindfactory)
Motherboard: Gigabyte GA-B150M-D3H Micro ATX LGA1151 Motherboard (€86.25 @ Mindfactory)
Memory: Crucial 8GB (1 x 8GB) DDR4-2133 Memory (€25.75 @ Amazon Deutschland)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive (€47.99 @ Amazon Deutschland)
Case: Corsair SPEC-03 Red ATX Mid Tower Case (€60.89 @ Amazon Deutschland)
Power Supply: Antec High Current Gamer 520W 80+ Bronze Certified ATX Power Supply (€66.90 @ Caseking)
Operating System: Microsoft Windows 10 Home OEM 64-bit (€95.76 @ Mindfactory)
Other: AMD RX 480 (€160.00)
Total: €663.58
Generated by PCPartPicker 2016-06-09 23:56 CEST+0200
If you don't care about having a decent case, you could save money there, but I like having a good budget case like the Corsair SPEC 02/03 or 200R. The D3H has an extra x4 PCIe slot for future upgrades (e.g. USB 3.1, NVMe SSD.)
Wait for the RX 480. Definitely worth it.
