K Kurizmuh Prominent Feb 27, 2017 25 0 530 Feb 28, 2017 #1 Some people say that I should use a 1080p for it but others say that's overkill. All I want is a steady 60fps if not higher. I have a $500-700 budget. Thanks
raisonjohn Expert Ambassador Feb 22, 2015 4,102 103 39,040 Feb 28, 2017 #2 It can do 4K but wouldn't suggest it. Best to run 1440p (better visual acuity/distance and lesser power hog) to get that steady 60fps or even more. Upvote 0 Downvote
t53186 Distinguished Aug 6, 2006 1,720 1 20,465 Feb 28, 2017 #3 1080P is kinda considered a bare minimum these days, certainly not overkill Upvote -1 Downvote
guanyu210379 Illustrious Mar 30, 2007 7,681 25 38,115 Feb 28, 2017 #4 For a GTX1080, the best monitor you can get is something like Acer XB271HU or ASUS PG279Q. If you can live without GSync, ASUS MG279Q is ok. Upvote 0 Downvote
K Kurizmuh Prominent Feb 27, 2017 25 0 530 Feb 28, 2017 #5 t53186 : 1080P is kinda considered a bare minimum these days, certainly not overkill Sorry I meant the GTX 1080 is over kill for the 1080p Upvote 0 Downvote
