The GT440 isn't much of a card for $100 btw.
- Better off with a Radeon HD7750 >= 850MHz.
The original ones can still be found that don't have the requirement of a 6-pin PCIe power connector and they'll work with a lower grade power supply unit.
They offer the HD7770, so I'll use that for comparison:
- http://www.hwcompare.com/11912/geforce-gt-440-3gb-vs-radeon-hd-7770/
But after reading the reviews I can't say I recommend it...
http://scottdbowen.id.au/hp/HP%20ENVY%20h8-1420t.png
- The other reviews are mostly good or neutral, but it appears that they don't upgrade the PSU when you order it with a 'top of the line' video card, even though the cards are listed as supported.
Over USD$2,000 for a decent configuration... you're kidding me, right?
http://scottdbowen.id.au/hp/Over%202%20grand%20-%20You%27re%20kidding%20me!.png
- I cannot recommend this machine for the life of me.
They also let people buy it with Windows 8 (32-bit) even though the base configuration is 8GB RAM.
- That's piss poor QA demonstrated right there.
- It won't be able to use half the RAM it ships with if people do that (and that is the default, which makes it even worse!).
On a side note, the build quality of the HP ENVY LAPTOPS is much better!
- They might not have the 3D grunt you're after though.
- I can, and do, recommend HP/Compaq laptops.
