[SOLVED] what kinda of hardware do i need for 4k streaming (none gaming )
asben
31
hello , i was looking for some advice about 4k video streaming only . Do i need i need a beefy graphics ? or would something like a 1660 would suffice??. i`m planning on buying 2 4k 35 inch ultra wide monitors
A weak intel igpu can run 2 4k videos. You don't need anything more than a cheap office pc.
Yup this,although you would have to make sure that you get a recent intel one and one with a mobo that also has two hdmi ports which as far as I know is extremely rare.
I don't know how well AMD APUs would run two 4k video streams at the same time but they should be ok as well.
Also if you mean stream from the internet two 4k videos at the same time will tax your internet connection more than anything else so you need a good one and in some places it's pretty impossible to get one.
