Question What MacBook laptop is right for using dual 2560 x 1440 resolution monitors?
Mar 9, 2019
I have two HP Pavilion 27q Display monitors(https://store.hp.com/us/en/pdp/hp-pavilion-27q-display). I am a Mac user, and I am trying to figure out which model would be strong enough to run smoothly with both of these monitors at the same time. I am tired of the lag I have with my current MacBook Pro, which is the Early 2015 version with the Intel Iris Graphics 6100 1536 MB graphics card.
Your current Macbook Pro should run those fine. How are you connected? If using a dock you need to be careful it is simply passing through the video signal. Many docks use their own built in GPU. Which can cause a lot of lag. Same goes with USB adapters.
Similar threads
