What memory card will work on my Dell Optiplex 755?
Aug 28, 2018
My Dell Optiplex 755 needs more memory. My system is Intel (R) Core (TM) Duo CPUs 2.20 GHz and l 2.19GHZ, Installed Memory 2.00 GB System Type 64-bit Operating system. What do I buy that works and will improve speed and efficiency.
normally on a OptiPlex 755 (and you need to confirm this by looking inside the case) the system has 4 slots for ram, ands 8GB is the highest in 99% of cases for 775 CPUs' thus DDR-800/667 being the two possible speeds used on the said motherboard.
Ao your looking at DDR2-6667 or DDR-800mhz, 4x2GB DDR2 ram NON ECC you will need to buy them as a quad pack or two sets of two
matching your current 2Gb to another is not a good idea on this type of motherboard, it will likely lead to more issues than solutions.
it will improves the system speed yes... I run a Q9400/8GB and when it was a 2Gb it was painful to use, now it runs win 10 and with a GT720 it is a perfectly good workstation to have in my office.
I would not use an SATA SSD, the loss of performance on a 6GB/s SATA they are designed force to run as a 3GB/s on your motherboard will not show great improvement over a 7200 HDD to be honest.
Also, if necessary, RAM can be upgraded to 16 GB, I have a few Dell Community posts about supporting this statement.
