I have a question I am building a new pc and i got the cooler master 212 EVO and Im not sure if it wil fit.
The motherboard the Asus M5A99FX PRO R2.0 ATX AM3+
Computer Case Roswell RIZE full Tower
Video card I picked out for this EVGA GeForce GT 610 1GB Video Card
What Memory will fit and are good to OC
G.Skill Ares Series
DDR3-2133 CAS 9
8GB (2x4GB)
240-pin DIMM
http://pcpartpicker.com/part/gskill-memory-f32133c9d8gab
G.Skill Ripjaws X Series
DDR3-2133 CAS 10
8GB (2x4GB)
240-pin DIMM
http://pcpartpicker.com/part/gskill-memory-f32133c10d8gxm
Corsair Vengeance
DDR3-1866 CAS 9
8GB (2x4GB)
240-pin DIMM
http://pcpartpicker.com/part/corsair-memory-cmz8gx3m2a1866c9b
This one I like a lot but not sure it's worth it. it's LED blue
Crucial Ballistix Tactical Tracer
DDR3-1866 CAS 9
8GB (2x4GB)
240-pin DIMM
blue/orange LED
http://pcpartpicker.com/part/crucial-memory-blt2kit4g3d1869dt2txob
Also There is a question I been looking at the motherboard and I cant seem to fine a case speaker connecter. My computer case did not come with one. and I not sure I need one. because one day I'm going to need to Troubleshoot the board.
Is there a build in computer speaker? I did not fine a connecter all I is boot device LED
FAQ:
Why pick the Phenom II X2 565 because This system is not to play games I have XBOX360 for that I am using it to play runescape on high settings, Netflix a streaming movies and little soft video editing TV shows. as in cutting the previews and credits off to make small size files. Latter if I want to play games on here then I can upgrade to a 6300 FX. And plus I'm on a budget
Why I picked the high end board with a x2 cpu because it's all set all need to do is upgrade the CPU and not both.
Why the EVGA GeForce GT 610 1GB Video Card Because I only need it for what I am doing plus im on a budget next month or so ill upgrade to a higher one. or return it with in 30 days and get a better one. I only need it for 3 displays 1 vga 17 in 1 dvi to hdmi 23 in and 1 hdmi 42 in
1 to play runescape one to watch movies and the other to surf the web.
Thanks in advance on who helped
G.Skill Ares Series
DDR3-2133 CAS 9
8GB (2x4GB)
240-pin DIMM
DDR3-2133 CAS 10
8GB (2x4GB)
240-pin DIMM
Corsair Vengeance
DDR3-1866 CAS 9
8GB (2x4GB)
240-pin DIMM
DDR3-1866 CAS 9
8GB (2x4GB)
240-pin DIMM
blue/orange LED
FAQ:
