What Minimum Power Supply do I need?
Blackout621
54
What's the minimum power supply I need? I have seen places I'd be fine with a 900W PSU. Time to ask you guys!
Specs:
-Oc'd i7 2600k (aftermarket heatsink)
-4 case fans
-2 Asus GTX 580s
-Asus Maximus IV Extreme-Z motherboard
-2 1.5 TB 7200 RPM Hard drives
-16 GB of DDR3 1600
-Possibly a RAID controller
-DVD/CD Burner
I won't be benchmarking this thing 24/7 or anything.. just probably about 2 hours a day of extreme gaming.
So my question to you guys is, will an Antec Gaming Series 900W psu power my system?
Yes the Antec High Current Gamer HCG-900 would be a good choice for your build with some headroom, so hopefully the fan won't have to spin loudly.
I'd say that 850W is an absolute minimum, so anything over that will mean that your PSU should have to work less hard.
lilotimz
875
The Corsair AX850 is based off the Seasonic X series which is heavily overspec'd compared to the actual power it can give off. IIRC, the original X850 can put up over 1000watt's and still remain in spec.
http://www.hardwaresecrets.com/article/Seasonic-X-Series-850-W-Power-Supply-Review/1169/8
Don't ever underestimate Seasonic products!
But yes, a very high quality 850w will be your best choice since under normal conditions, you'll be generally using around 500-600watts.
