what motherboard and water cooler to get?
gameboy14
6
Hi guys,
I am getting a new computer:
i5-4690k,nvidia gtx970,gskill ripjaws x 8gb(4*2) 1866mhz,1tb HD,corsair vs650.
i don't know what motherboard should i choose. I want a z97 motherboard.
please help me select a good motherboard under 10000 INR
and also a good water cpu cooler under 5000 INR
The Gigabyte GA Z97-D3H will work great. Now remember if you do not have adequate cooling you are limiting the performance of all of these other nice parts you have. It is nice to allow your pc to run cool and not under stress.
so basically I can go gigabyte ga z97 -d3h motherboard.
Even I was thinking about getting a good water cooler so probably i can somehow manage to get the corsair h100i gtx,will that be compatible with this motherboard
Yes that motherboard will work just fine, it has great overclocking potential as well.
The cooler is more compatible with your case in terms of size, I would research that a lot as some people buy one of the Corsair Hydro Series coolers and it ends up not fitting in their case.
i am thinking to buy corsair spec 03 or cooler master k380 cabinet. will that be fine to mount the water cooler.
If not please suggest me some good mid tower atx cabinet under 5000 INR
I went through the list and found few good cabinets in my budget.I finally decided to get the gigabyte ga z97m-d3h motherboard,corsair h110i gtx along with nzxt h440 micro atx mid tower..
Thanks for your help.
