S some body Prominent Mar 1, 2017 12 0 510 Feb 19, 2018 #1 should i go for a c14s by noctua or the noctua u9s for an itx builds which one will cool better dont worry about the case i got that checked i just need to know which cools bettert
Solution Darkbreeze Feb 19, 2018 The C14S will cool better by far. You're talking about a 140mm fan vs a 92mm fan. Not hard to figure out which of those has a higher rated TDP. Plus, the C14 is THE top rated low profile cooler on Frostytech. http://www.frostytech.com/top5_lowprofile_heatsinks.cfm
Darkbreeze Retired Mod Jun 24, 2014 80,326 7,597 176,790 Feb 19, 2018 Solution #2 The C14S will cool better by far. You're talking about a 140mm fan vs a 92mm fan. Not hard to figure out which of those has a higher rated TDP. Plus, the C14 is THE top rated low profile cooler on Frostytech. http://www.frostytech.com/top5_lowprofile_heatsinks.cfm Upvote 0 Downvote Solution
