What outdoor security cameras are compatible with using Windows phones as a viewer ?
Gary_7000
4
I have tried researching this, and it can be confusing trying to be sure which outdoor security cameras are truly compatible with using a Windows phone as a viewer. (We have home WIFI which our phones connect to also, as well as a data plan for when away from home)
I found an app on the Windows store called "IP CENTCOM" that says cameras that use ONVIF should be compatible but when I search online for ONVIF based cameras (like on Amazon) the description will only mention being android and IOS compatible.
I'd like to find an outdoor security camera that:
Is compatible with using my Windows phone as a viewer
Is priced under $100
Has night vision preferably to at least 50 feet
Has decent reviews so I can feel it will be worth getting
Any suggestions on any such cameras is appreciated !
Gary
Thanks for the reply, even though you could not recommend your camera since it is not an outdoor camera at least your reply let me know that app worked okay for you. Thanks again !
