[SOLVED] What parts do I need for a streaming PC with a budget of $550
XHunterYT
20
Hello, i'm looking for a PC with parts that can handle 1080p streaming w/60FPS while running games like Minecraft, Raft, and other similar games like those.
More of a casual gamer, not really a fan of the AAA titles, so I just need something that can handle games like Minecraft and Raft while streaming them at a good quality.
You couldn't have chosen a worse time for a build at your budget due to the lack of video cards available atm. This cpu down below has integrated graphics that you can use until affordable video cards become available and even then you're probably going to have to bump up your budget by $100 - $200 dollars.
https://www.newegg.com/black-fractal-design-core-1100-micro-atx-mini-tower/p/N82E16811352039
Fractal Design Core 1100, Black, Micro ATX, Mini Tower $29.99
https://www.newegg.com/corsair-vs-series-vs500-cp-9020223-na-500w/p/N82E16817139267
CORSAIR VS Series VS500 500W 80 PLUS Certified Non-Modular ATX Power Supply, CP-9020223-NA $49.99
https://www.newegg.com/p/N82E16813157943
ASRock H410M-HDV/M.2 LGA 1200...
With the GPU prices right now,buillding a budget build with a gpu,especially at 550$ is imposible but here is something i put together.
https://pcpartpicker.com/list/xdm3j2
3200g should be able to stream and play both minecraft and raft,paired that with a solid b450 board for future upgradability.
Added 2x8gb 3200mhz ram which is kind of a sweet spot for 3200g.
500gb ssd should be good for now,but you can buy a 1tb hdd later on if u want.
P300a mesh is a pretty good for 50$,tons of airflow and cooling support.
A good 550W psu is all you need pretty much.
The prices of GPUs arent going to go down much until april,so ur gonna have to be patient,and if you save 200-250$,you should be able to get urself a 1660 super on the used market which would definitely improve your overall gaming and streaming experience
Reactions: Why_Me
ASRock H410M-HDV/M.2 LGA 1200 $64.99
https://www.newegg.com/intel-core-i3-10100-core-i3-10th-gen/p/N82E16819118138
Intel Core i3-10100 Comet Lake Quad-Core 3.6 GHz $125.45
https://www.newegg.com/g-skill-16gb-288-pin-ddr4-sdram/p/N82E16820232718
G.SKILL Aegis 16GB (2 x 8GB) 288-Pin DDR4 SDRAM DDR4 2666 (PC4 21300) Desktop Memory Model F4-2666C19D-16GIS $66.99
Total: $337.41
https://www.newegg.com/crucial-bx500-480gb/p/N82E16820156188
Crucial BX500 480GB 3D NAND SATA 2.5-Inch Internal SSD, up to 540 MB/s - CT480BX500SSD1 $46.99
or ...
https://www.newegg.com/team-group-960gb-cx1/p/N82E16820331558
Team Group CX1 2.5" 960GB SATA III Internal Solid State Drive (SSD) T253X5960G0C101 $83.99
Better PSU
https://www.newegg.com/evga-500-bq-110-bq-0500-k1-500w/p/N82E16817438101
EVGA 110-BQ-0500-K1 500 BQ 80 Plus Bronze Semi Modular 500W Power Supply $59.99
Better CPU
https://www.newegg.com/intel-core-i5-10400f-core-i5-10th-gen/p/N82E16819118132
Intel Core i5-10400F $164.99
Faster RAM
https://www.newegg.com/hyperx-16gb-288-pin-ddr4-sdram/p/0RN-0003-000B5
HyperX Fury 16GB (2 x 8GB) DDR4 2666MHz DRAM (Desktop Memory) CL16 1.2V Black DIMM (288-pin) HX426C16FB2K2/16 (Intel XMP, AMD Ryzen) $72.64
https://www.newegg.com/corsair-vs-series-vs500-cp-9020223-na-500w/p/N82E16817139267 $49.99
Total: $337.41
or ...
Better PSU
Better CPU
Faster RAM
Shame intel doesnt have cpu's with good igpu as ryzen has.I wonder if they are ever gonna make a good cpu with good igpu in it,would be a really good budget option,and a potential competitor to the 3200g.
But for me the best apu is definitely 3200g,especially after i saw what it can do on my friends pc.
10400f doesnt have a igpu tho so he is going to have to buy a gpu if he wants any output.
A solid gpu for i3 10100 would probably be gtx 16 series,but even now,geez,300$ for a small form factor 1650,crazy
Reactions: Why_Me
I don't know if Rocket Lake will have the same igpu or a better one. Either way Rocket Lake is going to be a dud imo. Alder Lake on the other hand should be a big step up from where Intel is today .. I hope.
Reactions: Dj0gany
