Do you have any sort of priorities such as processor graphics card etc? and what will you be using this for?
PCPartPicker Part List
CPU: AMD - Ryzen 7 2700X 3.7 GHz 8-Core Processor (£249.96 @ Box Limited)
Motherboard: ASRock - B450M Steel Legend Micro ATX AM4 Motherboard (£82.48 @ Amazon UK)
Memory: G.Skill - Ripjaws V Series 16 GB (2 x 8 GB) DDR4-3200 Memory (£87.15 @ Amazon UK)
Storage: Intel - 660p Series 512 GB M.2-2280 Solid State Drive (£65.45 @ CCL Computers)
Case: Fractal Design - Focus G Mini MicroATX Mini Tower Case (£46.36 @ Aria PC)
Power Supply: SeaSonic - FOCUS Plus Gold 550 W 80+ Gold Certified Fully Modular ATX Power Supply (£78.11 @ Ebuyer)
Operating System: Microsoft - Windows 10 Home OEM 64-bit (£82.38 @ Aria PC)
Custom: RTX 2070 Super 8gb (£499.99)
Total: £1191.88
Generated by PCPartPicker 2019-07-07 20:04 BST+0100
Or the CPU to the 3700X however then I think you need to change the motherboard to a X470, then you'll need to change the case to a ATX version or a different case.Thanks 😀 I have a spare copy of windows so i was thinking about maybe upgrading the motherboard to a MSI Carbon MB
Change the EVO to the Intel 660P 1TB NVMe, it fast enough that you won't notice the difference and saves you a considerable amount of money. Use some of those savings on the memory and get 3200mhz instead of 3000 as Ryzen performs better with faster memory. You could also use part of the savings to go X470 instead as I'm not sure if the B450 boards will work out of the box without a BIOS upgrade. Everything else looks good.How does this look to you? https://uk.pcpartpicker.com/list/DhG93b
