So here is my build I've been slowly upgrading https://pcpartpicker.com/user/Strattton/builds/ So previously I had an R9 270x which has two 6 pin connectors. I have an EVGA SuperNOVA G2 850W which comes with two 6 pin cables. So I opted to think that plugging in two separate 6 pin cables would do the trick. Turns out, nope. So I found out that I had to use a single 8 pin to two 6 pins cable. Why is that? I've seen threads where people state that you can use two cables but I can tell you it didn't work for me, and I'm pretty tech savvy.
Second and more importantly. I want to get custom sleeved cables from cablemod for a 1070 and it requires an 8 pin and 6 pin, what cables or cable should I get using their configurator?
