Question What pins on the motherboard does the Ryzen 1700's wraith led cooler, rgb pins go?
Jul 29, 2018
58
Whats the name of the pins on the motherboard where you connect the led cable to the back of the wraith cooler called?
Is it LED_C1? Thats my only guess.
Karadjgne
Herald
-When the 4 pin connector on the Wraith Prism is connected to your RGB header on the motherboard, RGB Fusion will control and sync the Wraith Prism Fan LED, but NOT the outer ring LED or the AMD logo LED (these will always remain at default which is rainbow for the ring led and white for the AMD logo)
-When the Wraith Prism is connected to your motherboard using the USB header, the Coolermaster Wraith Prism Utility will have full control over all zones on the Wraith Prism including chase effects etc. But you will lose that SYNC functionality with RGB fusion.
Here's the thing though, if you've plugged in BOTH the 4-pin connector and the USB connector from the Wraith Prism to your motherboard, the Coolermaster Wraith Prism Utility will not take control. It defaults to the 4-pin mode and RGB Fusion overrides it (back to rainbow ring and white AMD logo only)
Reactions: rjcard32315
Jul 29, 2018
58
Thanks for the info
Similar threads
