What power supply do I need?!
Mark_145
Commendable
Apr 5, 2016
6
I'm not sure what power supply I will need for my pc build. I went onto a calculator and said my components use 503 watts. So what power supply would I need?
Thanks you :)
what are your specs? often calculators aren't the most reliable thing. getting a good quality PSU is important, never cheap out .
get a tier one or 2. http://www.tomshardware.com/forum/id-2547993/psu-tier-list.html
also it is also sort of dependent on your GPU too so here's another link http://www.realhardtechx.com/index_archivos/Page362.htm
but coming off the calculator, get a 550W from EVGA SuperNova series (not NEX, they are bad quality), or a good 550w from seasonic . a 750w will allow you to add another GPU in the future. a 600w will allow extra room for overclocking. 600w- EVGA Supernova 650 or 600B, or Seasonic 620w
