What power supply for this build?
Rockstar525
36
I'm just looking for what size power supply would fit this BUDGET build and other suggestions would help to. Thanks
CPU: Intel Pentium G3258 3.2GHz Dual-Core Processor
CPU Cooler: Cooler Master Hyper TX3 54.8 CFM Sleeve Bearing CPU Cooler
Motherboard: ASRock H97M-ITX/AC Mini ITX LGA1150 Motherboard
Memory: G.Skill Ares Series 8GB (2 x 4GB) DDR3-1600 Memory
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA GeForce GTX 750 Ti 2GB Superclocked Video Card
Case: Thermaltake Core V1 Mini ITX Tower Case
Your CPU and GPU are not demanding. Even with overclocking you'll be fine with 450W.
Here's some suggestions:
Entry-level quality: http://pcpartpicker.com/part/antec-power-supply-vp450
Mid-range: http://pcpartpicker.com/part/antec-power-supply-hcg520m
Premium: http://pcpartpicker.com/part/evga-power-supply-220gs0550v1
If it was me, using the rebates I'd go for the Antec HCGM (mid-range). It's got extra headroom in case you decide to upgrade the GPU/CPU in the future, it's very well made and is modular.
This 550w will leave you room to upgrade.
Power Supply: XFX 550W 80+ Bronze Certified ATX Power Supply ($50.40 @ SuperBiiz)
Total: $50.40
Generated by PCPartPicker 2015-09-05 18:04 EDT-0400
