[SOLVED] what power supply is good for my build
Apr 1, 2021
13
Cooler Master V-Series V1000 Gold+ 1000W
Thermaltake Toughpower Grand RGB 850W Gold
Gigabyte P850GM 850W 80 PLUS Gold Certified
Mobo: GIGABYTE B550 GAMING X v2
Cpu: AMD Ryzen 9 3950X
Gpu: GeForce GTX 1080 Ti
Gpu: GeForce GTX 1050 Ti
Nvme: 2x Samsung 980 3.0
Ssd: 2x ssd
Hdd: 1x hdd
Fans: 10 fans
If running two GPUS, I would pick something off the list. Toms hardware and Linus both have lists.
Get the best tier you can afford. I really like the HXI and P2's. If you can afford two GPU's and 3950x don't skimp on a power supply
Out of those three I recommend the CM, the V1000 is an old PSU that I believe is no longer in production, replaced by the V1000 platinum. But I think it is still the best out of the three. The Thermaltake is decent, but it has malfunctioning OTP (Over Temperature Protection) (or no OTP at all). The Gigabyte is a terrible PSU, as it managed to blow up during Aris' review.
Build
Motherboard:Gigabyte B550 Gaming x V2
CPU (Processor):Amd Ryzen 7 3700x
GPU (Graphic Card): GeForce GTX 1050 ti but later i am going to install 2nd GeForce GTX 1080 ti for redshift rendering in c4d.
Ram: GSkill Ripjaws V 4x8
Storage: SAMSUNG 980 and 1 sdd and 2 hdd
Fans 10 fans
i have a budget for these two, which is the best one ?
1st Player PS850SP
Gigabyte P850GM
these are also the options i have:
Adata XPG Core Reactor 850W
Cougar GEX850 Fully Modular 80 Plus Gold
Antec HCG 850 80+Plus Gold Certified Fully Modular
