What power supply should I buy , or how many watts?
conceptone
Commendable
May 4, 2016
15
Hi I'm going to buy a computer this week and I don't know how much watts do I need for this build.
Specs:
I7 7700
MSI GTX 1060 6gb
Asus Prime H270 plus
DDR4 Gskillripjaws v 16 gb dual
Western Digital 2tb
Sandisk 128 SSD
Cooler Master Hyper 212 led
Power supply: ?????? (watts???) I was wondering if i should buy the corsair vs650
I'm going to use the pc for 5-10 hours
Corsair CX450M should be fine for your system, bronze rated, for $54 on Amazon if on a budget. If not, it couldn't hurt to choose a better one. You may be able to find a sale on a quality 430w or higher psu, though 450w-500w is plenty of power for your sys. Here's a link that may be helpful, from this site listing PSU tiers. http://www.tomshardware.com/forum/id-2547993/psu-tier-list.html
Note: Max1s question is important. If you aren't sure whether you'll be upgrading your gpu or adding other components, drives, fans, etc, later, then considering a psu with higher wattage would be your best bet.
Are you planning on sticking with these components or are you going to move to a bigger graphics card (for example) in the future? If not then there's no reason to exceed what you need at the moment, although with PSU's it's better to have too much rather than too little. 🙂
having too many watts is not a problem to little and will slow components down a good 550 watt would be good
PSU Tier list tier 1-2 are good for gaming
http://www.tomshardware.co.uk/forum/id-2547993/psu-tier-list.html
I would recommend an EVGA SuperNova Gold G2 / GS / GQ, Platinum P2 / PS, or Titanium T2 or a Seasonic M12-II Evo or S12-II
GOOD PSU EVGA is a B2, G2, P2, GS, PS, or T2. Avoid the EVGA B1 and G1 series
What your asking can be easily answered by your self, look at all the spec for all the components going to be using , CPU, GPU, RAM, HHD, SSD, FANS, LIGHTING, MODEMS, etc, for max power required to run them all efficiently under load, or accelerated, Do a little Math, An you'll have your answer, no one can really answer that question correctly with out knowing the full scale of your use, an full component use list at present on the Build, for instance the i7 core may only use 30 to 70 watts under load Depending on the size of the Core, but What's the fan keeping it cool going to use ? But if your asking for a good guess, by the sounds of your Hardware Spec I would not use anything under a good 500W PSU no crap
unless you like learning how to trouble shoot power shortages, an hardware malfunctions, Better to over Kill then to Under Power I say. Good Luck!
