Question what power supply should i get?
joshuablofield123
Commendable
May 29, 2018
37
i will be shortly ordering myself a asus rog strix oc 2080 ti, i9 9900k, 4x8GB 4200mhz ram and aorus z390 master.
i know this mother board requires 2 8 pins and 1 24 pin and also the graphics card requires 2 8 pins.
im also not sure what watt psu i should get but with that i also need enough sockets?
Would make more sense to have 2x16GB RAM instead of 4x8GB. Also considering the build I assume you have a pretty hefty budget, you could go with the Seasonic Prime Ultra Platinum or Titanium at 750/850W.
D
Deleted member 14196
Guest
get a good surge suppressor to power and protect your investments too. up to $50,000 protection for everything plugged into it, even if it gets fried by lightning, they buy you new stuff to replace the fried stuff, if it ever happens, which it doesn't
if your pc and stuff ever got hurt, they buy you new ones! I have never had one fail yet. I worked for an electric company and they use them for all their PC needs for a reason. They are beefy and good. so protect that pc and nice SeaSonic PSU
