What power supply should I use for SLIed EVGA Gtx 760 oc ACX
FrothingLoins
12
Greetings community!
I know absolutely NOTHING about PSUs.
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131874 is my mobo
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130932 is the video card.
I plan on overclocking both cards 90 on their core clocks and 600 on the mem clocks (I am running this OC profile using precision X with a single card right now and have 100 system stability with a 550w power supply. In Precision X I do have overvoltage enabled and set to 12.0 mv)
Dark Lord of Tech
Speedy Gonzales
Made by SEASONIC.
Power Supply: Antec HCG M 750W 80+ Bronze Certified Semi-Modular ATX Power Supply ($79.99 @ NCIX US)
Total: $79.99
(Generated by PCPartPicker 2014-02-18 10:50 EST-0500)
OR
Power Supply: XFX 750W 80+ Bronze Certified Semi-Modular ATX Power Supply ($99.99 @ NCIX US)
Total: $99.99
(Generated by PCPartPicker 2014-02-18 10:51 EST-0500)
ImPrettyIrish
832
73
550 is enough. Where did you see that it wasn't?
06yfz450ridr
2,610
304
550w for a single card is fine but not for sli, I would recommend a 750w
Dark Lord of Tech
Speedy Gonzales
The CX750 is a budget power supply with cheap capacitors and lacks 2 needed PCIE connections.
PCI-Express Connector
2 x 6-Pin
You need 2 - 6+2 and 2 - 6pin
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139051
Has the right connections on the newer semi-modular version.
4 - 6+2
thdarkshadow
895
97
I own the cx750 and just bought the seasonic I linked to replace it. The CX is loud and while it powers my system I wouldn't do sli 760s with it. Not saying it can't power it just I wouldn't. And for $90 you can get a better PSU
FrothingLoins
12
Would http://www.newegg.com/Product/Product.aspx?Item=N82E16817139055 work? I'm a bit of a corsair fanboy.
Edit---> I just saw your edit. Would you say the difference in price is worth the power efficiency? I'm not adverse to spending a bit more for an all around better product.
thdarkshadow
895
97
That's a good psu but it's listed as $130 and the better seasonic that I linked is $120 after the promo code and before another $20 mail in rebate making it $99 after the mail in. The platinum series by seasonic are some of the best power supplies money can buy. Just a thought. Now if you can get that rm750 for less it is also great just not quite as good
Similar threads
