What power supply will I need?
hughisthewinger
47
I'm building my first PC in 2 weeks times and I don't know what PSU to get. I will be running a gtx 780, however I live in New Zealand and the prices of PSU's over here are really expensive:
I was looking at:
-Antec 750W EarthWatts Green
-Corsair TX750
-CoolerMaster Silent Pro M 600w
-Corsair TX650
-Corsair HX620w
Are any of these PSU's any good? I don't want to buy something really cheap that will be useless so if you guys have any other suggestions that would be great. I will spend more if I have to.
Cheers
G
A corsair 650tx should be more than enough. If you want to "future proof" though I would get the 750tx
Remember to choose the best answer! :)
For a system using a single GeForce GTX 780 graphics card NVIDIA specifies a minimum of a 600 Watt or greater system power supply that has a maximum combined +12 Volt continuous current rating of 42 Amps or greater and that has at least one 6-pin and one 8-pin PCI Express supplementary power connectors.
Total Power Supply Wattage is NOT the crucial factor in power supply selection!!! Sufficient Total Combined Continuous Power/Current Available on the +12V Rail(s) rated at 45°C - 50°C ambient temperature, is the most critical factor.
Overclocking of the CPU and/or GPU(s) may require an additional increase to the maximum combined +12 Volt continuous current ratings, recommended above, to meet the increase in power required for the overclock. The additional amount required will depend on the magnitude of the overclock being attempted.
Antec 750W EarthWatts Green (EA-750 Green)
• OEM: Delta Electronics
• maximum combined +12 Volt continuous current rating of 62 Amps
• four (6+2)-pin PCI Express supplementary power connectors
• 80 PLUS BRONZE Efficiency Certification
• 3 Year Limited Warranty
Corsair TX750 (SKU # 75-001309 / CP-9020042)
• OEM: Chicony Power Technology
• 5 Year Limited Warranty
CoolerMaster Silent Pro M 600w (RS-600-AMBA-D3) Discontinued
• OEM: Enhance Electronics
• maximum combined +12 Volt continuous current rating of 40 Amps
• two (6+2)-pin PCI Express supplementary power connectors
Corsair TX650 (SKU # 75-001315 / CP-9020038)
• OEM: CWT (i.e. Channel Well Technology)
• maximum combined +12 Volt continuous current rating of 54 Amps
Corsair HX620w (CMPSU-620HX) Discontinued
• OEM: Seasonic
• maximum combined +12 Volt continuous current rating of 50 Amps
• two 6-pin PCI Express supplementary power connectors
• 80 PLUS STANDARD Efficiency Certification
