What problems can cause on my gpu if my pc is running 24/7 ?
Shafin Ibne Mahmud
i am a torrent freak, downloads and uploads never come to an end, so , as a result, my pc runs almost 6-7 days non-stop with gaming sessions in between, and gets rest for almost 1 day after a whole week. I'm occupied with gtx 660 ti graphics and i5 intel core n 8gb ram. I really am frustrated about it's health and well being.. I really would like to know what possible drawbacks (major ones) can this usage of 24/7 of my PC cause on my GPU ? and also the rest apparatuses.
Eagerly waiting for your answers. Thank you. :)
First of all sorry for my bad English. Well, the awnser is quite simple I guess. If something gets used, it is more likely to have a shorter life than something that isn't used. On the other hand, if you keep your PC at low tempatures when you're away to increase the life of your parts it should be no biggy. Harddisks on the other hand are constantly writing while downloading.
It shouldn't be that big of a problem. I know someone that does basicly the same thing and has a simalar setup. So don't worry too much about it. If you clean out the dust once in a while and keep it at low tempatures (as i said before) it shouldn't be a problem.
