[SOLVED] What PSU should I get for R7 2700x and RTX 2060
Aug 29, 2019
I have built a PC and after 2 months my current PSU (CoolerMaster MWE Gold) started making very loud coil whine so I am replacing it as I live in NZ there is only a few models to choose from what PSU would you recommend out of:
EVGA B3 650W
Thermaltake Smart Pro RGB 650w
Corsair TX 550M V3
be quiet! Pure Power 10 CM 600W
EVGA B3 650W
Corsair TX 550M V3
The Thermaltake is not even in the running here...nuff said. Both the Corsair and Be Quiet PP10 are good models. Since you're in NZ you may want to consider if one or the other is easier to get warranty service on, if needed. Personally, I'd choose the Corsair TXM since I prefer a model with a single +12 volt rail and hits the Gold rating for efficiency.
EVGA B3 650W
Corsair TX 550M V3
