B BenjaminG Commendable Dec 29, 2016 14 0 1,510 Jan 3, 2017 #1 I currently have a cooler master elite 400w, will this work with the rx 470?
Solution Multipack Jan 3, 2017 500w is recommended for the RX 470 but should be ok. Which model rx 470 is it? I wouldnt try OCing it put it that way. The PSU is tier four so pretty unreliable http://www.tomshardware.co.uk/forum/id-2547993/psu-tier-list.html?_ga=1.151155836.499395850.1474638331
Dark Lord of Tech Retired Moderator Aug 18, 2009 128,733 1,824 159,590 Jan 3, 2017 #2 Get a decent 450w , to run it. Upvote 0 Downvote
Multipack Honorable Sep 5, 2016 4,283 3 9,960 Jan 3, 2017 Solution #3 500w is recommended for the RX 470 but should be ok. Which model rx 470 is it? I wouldnt try OCing it put it that way. The PSU is tier four so pretty unreliable http://www.tomshardware.co.uk/forum/id-2547993/psu-tier-list.html?_ga=1.151155836.499395850.1474638331 Upvote 0 Downvote Solution
Dark Lord of Tech Retired Moderator Aug 18, 2009 128,733 1,824 159,590 Jan 3, 2017 #4 PCPartPicker part list / Price breakdown by merchant Power Supply: SeaSonic S12II 430W 80+ Bronze Certified ATX Power Supply ($44.98 @ Newegg) Total: $44.98 Prices include shipping, taxes, and discounts when available Generated by PCPartPicker 2017-01-03 17:56 EST-0500 Upvote 0 Downvote
B BenjaminG Commendable Dec 29, 2016 14 0 1,510 Jan 3, 2017 #5 So are you saying my psu won't run the ex 470 My specs MSI main board mini atx Geforce gt 730 Amd fx-6300 1tb hard drive Upvote 0 Downvote
Dark Lord of Tech Retired Moderator Aug 18, 2009 128,733 1,824 159,590 Jan 3, 2017 #6 If it was a quality PSU I'd say it might run it , but I would upgrade. Upvote 1 Downvote
