Question What PSU to get for a future possible RTX 6090 graphics card?
raccoon1
17
Guys I'm in terrible need of help. If any of you can help I already give thanks in advance. Thing is I bought a power supply that is not compatible that is will not fit in the case because it's more than 200mm wide and the connectors are at the side and I will need to return it to the store. Thing is I need something compatible with the case and that can supply a future graphics card upgrade. I'm first buying a RTX 5080 graphics card then if possible upgrade it. All things need to be compatible. What to do? I don't know. This is my build
We just got news of the RTX5000 series, you're going to have to wait probably 2 or more years before the RTX6000 series is announced to the masses.
You could look at the HXi series;
https://www.corsair.com/us/en/p/psu...m-atx-1000-watt-pc-power-supply-cp-9020259-na
The 1000W variant is 180mm long.
Reactions: raccoon1
I built mine with a 1300W... enough for the 4000, 5000, 6000, 7000, 8000 and 9000 series. Rumor has it the RTX 10000 series will be 1200W by itself so I'll probably upgrade my PSU then.
Reactions: raccoon1 and ötzi
