What PSU Wattage will I need to power this build?
KALONZI
6
My Specs:
Case
CiT Vantage Type-R Gaming Case with HD Audio, 4 Fans, Card Reader and No PSU
Ram
2 x Crucial BLS4G3D1609DS1S00CEU Sport 4GB, Ballistix 240-pin DIMM, DDR3 PC3-12800 Memory Module (Cheaper than buying a set of two by 10p)
Monitor
Samsung SyncMaster 940BW 19" Widescreen LCD Monitor (Ebay Bid may not win)
Keyboard
Random keyboard I had luting around.
PSU
Corsair Builder Series ??? Watt
MOBO
Gigabyte B85-HD3 Motherboard (Socket 1150, Z87 Express, DDR3, S-ATA 600, ATX, Haswell, Supports 4thGeneration IntelCore Processors, GIGABYTE UEFI Dual BIOS)
OS
Windows 7 home premium 64bit
Hard Drive
Seagate 1TB 3.5 inch 7200RPM 64MB Cache SATA3 Hard Drive
Graphics Card
Sapphire Dual-X AMD Radeon R9 280X OC 3GB GDDR5 Graphics CardGraphics Card with Boost
Processor
Intel Core i5 i5-4690K CPU (Quad Core 3.5GHz Processor, 6MB Cache, Intel HD 4600 Graphics, Socket H3 LGA-1150)
Headset
DH-878 Surround Sound Stereo PC Gaming Headset & Microphone 3.5mm Jack
Mouse
Trust Optical Mouse Wired
Thanks in advance!
KALONZI.
Corsair Builders CX series are poor qual;ty.
Perfect fit , both made by SEASONIC.
Power Supply: Antec High Current Gamer 620W 80+ Bronze Certified Semi-Modular ATX Power Supply ($64.99 @ Newegg)
Total: $64.99
OR
Power Supply: XFX 650W 80+ Bronze Certified ATX Power Supply ($49.99 @ NCIX US)
Total: $49.99
Will a 600W one be enough as I am on a strict budget?
[/quotemsg]
The evga only saves $5,if you can't spend that little extra.What were you looking at yourself?
[/quotemsg]
A Corsair Builder Series CX 600 Watt ATX/EPS 80 PLUS Bronze Power Supply Unit
Just seen the EVGA and thank you, it's cheaper and better quality. Should probably mention I'm not American, I'm Welsh, but on amazon it is cheaper.
I did have a good look at your specs btw and this is not a good combination,either get the 4690K with a Z97 or if needed a Z87 motherboard (needs the,probably,latest bios) or get that motherboard with a 4690 or to save some money the 4460.
And if you're welsh go for this psu,
http://uk.pcpartpicker.com/part/xfx-power-supply-p1550sxxb9
according to the partpicker about as expensive as the evga and 550watts are more than enough.
