Question What PWM and A-RGB hub for 7 deepcool fans?
Lutfij
You can use this hub for the ARGB;
and then use a PWM splitter/hub of your choice to manage the PWM connections.
I do think that 7 fans is going to be impractical. What case are you working with?
Jun 11, 2022
74
5
35
Hey!
First off, thanks for the answer!
The A-RGB hub looks perfect for my specs, thanks!
Now to the case question:
I'm using a DeepCool Matrexx 70 3f without the frontpanel. 3xCF120 at the front, however, I'm using a Gammaxx AiO where I could find no Informations about the fans (not even in the manual) , but I'm guessing they are actially CF120 ones with just a little silicon (?) protection because of the cables. Not sure tho so sorry for my mistake in the Question.
And I'm using 1xCF120 at the back. Hope this helps!
Jun 11, 2022
74
5
35
Your link takes me to Deepcool's main site...please recheck your URL.
Its working for me, maybe because the link uses a german domain and not the US/whatever else one. Here are two different URL's:
-1
-2
Incase they didn’t work either:
-3
Hope they'll work & again, sorry for these problems.
Lutfij
https://www.deepcool.com/products/Cooling/cpuliquidcoolers/2021/11411.shtml
Fan Connector4-pin PWM
Bearing TypeHydro Bearing
Fan Rated Voltage12 VDC
Fan Rated Current0.17 A
Fan Power Consumption2.04 W
LED TypeAddressable RGB LED
LED Connector3-pin(+5V-D-G)
LED Rated Voltage5 VDC
LED Power Consumption2.25 W(PUMP)/ 6.6 W(FAN×3)
looking through the manual;
https://www.deepcool.com/download/pdf/GAMMAXX_L360_ARGB.PDF
you actually get a PWM fan splitter with the AIO. As for the ARGB connections, they look proprietary, you're going to need the hub that comes with the AIO.
Jun 11, 2022
74
5
35
soo uhh, it works w8th a B550-F Gaming?..
