[SOLVED] What radiator / AIO can be top mounted in a Mastercase Pro 5?
Garion
33
Hello! Out of curiosity, what is the biggest radiator I can put at the top of a Master Case Pro 5? The Corsair H110i never has fit well in it, heck, I don't have all the screws in it since they don't all line up even though it's a 280mm AIO. There is a small lip in front and back that the radiator has to fit between that the 110I spans over. It works, after a fashion, but I wanted to get a radiator or AIO that fits, which ones will? Thank you for your time.
So an H100I ? Ok, gonna reduce cooling by a tiny bit but it won't have a sliver of a gap between the fans and the radiator. >.< That on it's own will be a help. Cool!
The tray, the lips front and back, is what it's hanging up on and why there is a sliver of gap between the fans (in their cubby up top under the top cover) and the radiator.
