paschalis.sigmas Feb 18, 2018 11 0 10 Feb 18, 2018 #1 hi guys i am planning my hardline loop now my gpu block and cpu block are full nickel now what rad and fittings should i use is copper oke to use and just black chrome fittings or would that cause like corsion or anything
Solution Zedjulz316 Feb 20, 2018 The rule is not to mix copper and nickel with aluminium. So I suggest you get copper radiators to go with your Nickel.
Zedjulz316 Reputable Oct 9, 2015 182 0 4,860 Feb 20, 2018 Solution #2 The rule is not to mix copper and nickel with aluminium. So I suggest you get copper radiators to go with your Nickel. Upvote 0 Downvote Solution
