If you have two Lenovo 27" monitors and you want to span wallpaper across both, what resolution should you use for it to look good?
If you know the resolution of each monitor, you could just add the widths together. For example, 2 4K monitors would be 7680 by 2160; 2 QHD monitors would be 5120 by 1440. Math is simple.If you have two Lenovo 27" monitors and you want to span wallpaper across both, what resolution should you use for it to look good?
