what Resolution is 1080 x 2246 pixels
jeffreyhjkgf1
116
what i mean by what resolution i know this isnt the correct termfor this but i dont know how its called ok what i mean by resolution is for example:
1920x1080 = 1080p
What p is it
It's 2246p, that is if it uses progressive scanning instead of interlaced scanning. Some TVs are say 1080i or 720i, they would be using interlaced instead of progressive. 1080p is just stating that it has 1080 vertical pixels and uses progressive scanning which is superior to interlaced.
It's not 2246p because 720p or i and 1080p go by height so 2246 x 1080 would be 1080p too. Even if it is a phone, you still go by lowest just like 1920 x 1080 phones are called 1080p, not 1920p. You could say it's 2k which goes by width and covers multiple 2k wide resolutions but it's a non standard res so it's not going to have a commonly used shortened term which is just marketing for the most part anyways. You should say the res to not confuse it with 1920 x 1080 or 2560 x 1080 or other 1080 resolutions.
