IzzanScool :
derekullo :
There is no difference with the size.
The image is simply blown up larger
As mentioned above the 1920x1080p screen is only 1 inch bigger than 18.5 inch 1366x768 screen.
Both are smaller than your current 21.5 inch 1080p monitor.
So just to clarify,
All I have to do to make the cursor align is to maybe physically align the monitors itself to the bottom? (in turn also aligning the taskbars?)
The cursors will only align if the monitors are the same size.
Even if the taskbars are aligned the mouse will come out at a different area due to physics.
For example lets say you used your 21.5 inch 1080p screen and you bought the 19 inch 1080p that I linked earlier and put them side by side with the taskbars aligned.
With this setup due to the 21.5 inch monitor being slightly physically larger it will go about an inch higher than the 19 inch.
No surprise here.
The resolution is the literal number of pixel lines on the screen.
1920 vertical lines x 1080p horizontal lines
Lets say you counted each line and you started at line 200 on the 21.5 inch screen and moved your mouse straight left to the 19 inch.
(You may need a magnifying glass lol)
On the 19 inch screen the mouse would indeed come out at the 200th horizontal line on its screen, but due to the monitor and pixels being smaller on the 19 inch screen the mouse won't come out at the exact same spot due to the monitor size difference.
Let me know if that was clear enough.
