D David Dias Honorable Aug 14, 2013 1 0 10,510 Aug 14, 2013 #1 how i can connect 20 pc by wifi, and what kind of routher i needed
Solution hang-the-9 Aug 14, 2013 For that many, you would want a router with several access points setup, 20 computers on one wireless connection would be pretty slow. You could get a Linksys E2100L for the main router, then get something like this http://www.bing.com/shopping/linksys-wireless-n-access-point-with-dual-band-wap610n-wireless/p/08DA5FC1BE85C45F0001?q=linksys+access+point&lpq=linksys%20access%20point&FORM=HURE for half the computers to connect to. You can setup different SSID names or use the same one for both devices.
hang-the-9 Titan Mar 25, 2010 60,372 1,081 152,940 Aug 14, 2013 Solution #2 For that many, you would want a router with several access points setup, 20 computers on one wireless connection would be pretty slow. You could get a Linksys E2100L for the main router, then get something like this http://www.bing.com/shopping/linksys-wireless-n-access-point-with-dual-band-wap610n-wireless/p/08DA5FC1BE85C45F0001?q=linksys+access+point&lpq=linksys%20access%20point&FORM=HURE for half the computers to connect to. You can setup different SSID names or use the same one for both devices. Upvote 0 Downvote Solution
