What SATA cable do I need
flutie22
6
Hi
I am trying to put a sata dvd burner in my ide liteon 5005 dvd recorder. I believe I have the right match that works, I am using a 2.5"/3.5" Drive SATA to ATA IDE Card Converter Adapter
So now while I am waiting for adaptor to arrive, I need to know what sat cable I need.
on the back of my new dvd burner, it reads above connection...... SATA POWER P15 P1 and next to it...SATA DATA S7 S1
I believe the other connection on the adaptor is the same , perhaps 1 is male and one is female?
Thanks if any help is available as what cable to get, have been doing lots of searching, the ebay seller had no idea
In a PC, one of those (POWER) comes from the PSU. The other (DATA) connects to a SATA port on th motherboard.
In your DVD recorder, it apparently uses an IDE interface. Old style drive interface.
You might try one of these:
http://www.amazon.com/IDE-SATA-Adapter/dp/B000RK89M4
Whether it will fit inside is a different story.
Well I already have one on the way, if you could take a look and tell me if you think this is ok would be great :)
http://www.ebay.ca/itm/221128174226?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649
Thank You
Isn`t there quite a few choices between sata power cables, I am assuming there are male ends and female ends, mine is a 15 pin
http://www.ebay.com/itm/15-7-Pin-Male-to-Female-SATA-HDD-Power-Extension-Cable-/200543720142
Would this be the cable I need, I believe it is?
was unable to find a straight 15 pin male to female, perhaps the space requires they are hooked together, at any rate that was my original question that nobody really answered, but thank you for the helpful tips in the other regards
I am hoping I have solved it myself? Yes my question was in regards to what cable I needed
THANK YOU :)
I oprderd this cable was under 4 bucks with free shipping to Canada, not bad if its one I need
