I installed everything and tested my mobo outside the case to make sure it recieves power, then installed it into the case and plugged everything in including the GPU, turned it on, no beeps and no display, but my monitor switched from a "no signal" display to a black screen and the led switched from red to blue, indicating it was recieving a signal, but the screen remained black. I wonder if the gpu or Mobo was dead so I took out the gpu and let it run and I recieved 5 LONG beeps and I turned it off. I plugged in the GPU and it ran normally with no beeps, but the same problem with the monitor happened. I assume that a dead mobo wouldn't beep and a dead gpu wouldn't be able to send any signal. I used every HDMI in the house, and even tried a TV just because, and like the monitor, it gets a signal, but remains on a black screen. What could be the issue?
Specs:
Mobo: asrock ab350 pro4
cpu: ryzen r3 1200
ram: G.Skill ripjaws V series 8gb
gpu: gigabyte gtx 1050 ti
psu: evga b3 450w
HDD: wd blue 1tb
case: deepcool tesseract sw red
I already consulted the boot troubleshooting option list that people usually link, but no luck.
Specs:
cpu: ryzen r3 1200
psu: evga b3 450w
HDD: wd blue 1tb
