What settings do I use for Geforce GTX 650 2gb in FSX?
sfreeby
Hello,
I do not understand what settings will be most effective in Flight Sim X for my GTX 650 video card. Currently I have these settings and I'm getting "warbles" when I pan around:
Anisotropic Filtering = 8x
Antialiasing - FXAA = On
Antialiasing Gamma Correction = On
Antialiasing mode = Enhance the Application Setting
Antialiasing Setting = Use Global Setting 4X
Antialiasing Transparency = 8X Supersample
CUDA GPU's = Use Global Setting (all)
Max Pre-rendered frames = Use 3D Application setting
Multi-Display/Mixed GPU acceleration = Single Display performance mode
Power management mode = Adaptive
Texture Filtering - Neg LOD bus = Clamp
Texture Filtering Quality = High Quality
Threaded Optimization = Auto
Tripple Buffering - Use Glolbal setting (on)
Vertical Sync = Adaptive
These are my settings and I'm not sure if they're optimized correctly. Any help would be appreciated. Scott Freeby My computer specs are: Dell Studio XPS i7 435t/9000; 16 GB Ram; Dell U2412M monitor with 60 Hz refresh rate.
Thanks for your question. It has saved me asking exact same thing for fax and I'm using same graphics card as well.
How did you go and if you sorted the wobbles out, can you please help me as well. Thanks.
Sorry I ment to ask how and where did you change these settings for the card / game?
