[SOLVED] What should I go for? Lower end RTX 2070 or a 2060/2060s with better cooling?
99StefanRO
124
17
10,595
Hi everyone,
I am looking to upgrade my RX 580 to a RTX, but I find it difficult to choose between the:
  • ZOTAC GAMING GeForce RTX 2070 Mini which I've heard it has a lower end cooling because it's a small form factor GPU;
  • any RTX 2060 with better cooling (they are like 100 euros cheaper, and in this price range there are a lot of 2060 with decent to good cooling);
  • and the RTX 2060S that is priced similary to
For some reason I can't create a list in this post, sorry for the mess. (EDIT: I managed to do it)
What do you think will be better in my case? A worse cooled 2070 or a better cooled 2060/2060s? Will be paired either with the R5 2600, either with the R5 3600. The PSU is powerful enough to handle up to a 2080s and 3900x, so it won't be a problem.
